Resource centerBlog
Our advice for reading the Gartner® Magic Quadrant™ for Privileged Access Management before you buy
Oct 26, 2026
In our opinion, the Gartner® Magic Quadrant™ for Privileged Access Management is the most useful single document for building a PAM shortlist, provided you read it as a market map rather than a verdict.
The 2026 Gartner® Magic Quadrant™ for Privileged Access Management published on Oct. 21, 2026. If you own a PAM budget, a copy will reach you within days, and someone will ask what you plan to do about it. The default answer in most organizations, in our view, is to shortlist the top-right corner and start scheduling demos. That's the fastest way to waste the report. Here's a better way to read it.
How we interpret the Magic Quadrant
Gartner describes the Magic Quadrant this way:
A Gartner Magic Quadrant is a culmination of research in a specific market, giving you a wide-angle view of the relative positions of the market’s competitors. Use a Gartner Magic Quadrant as a first step to understanding the technology providers you might consider for a specific investment opportunity.
What we believe the report can't do is know your environment. A solution carrying a large footprint and a long feature list may be a poor fit for an organization whose real problem is an overpopulated Domain Admins group. A lighter-weight, fit-for-purpose solution may be exactly right for it. In our opinion, Gartner is explicit on this point. That disclaimer appears in full at the bottom of this post. Treat it as an instruction.
We believe it's valuable to consult the Gartner Critical Capabilities research that complements the Magic Quadrant. Gartner describes it like this:
It shows you which products or services are a best fit in various use cases to provide you actionable advice on which products/services you should add to your vendor shortlists for further evaluation.
In our view, Gartner Critical Capabilities for Privileged Access Management is worth reading alongside this year's Magic Quadrant.
There are two things we feel the report does better than anything else you'll read on this topic. It settles what "PAM" means before your team starts arguing about products. And it applies one consistent set of criteria to every vendor at the same time, which no sequence of vendor demos will ever give you.
Why privileged access is the category where this matters most
Plenty of security tools can underperform for a year without anyone noticing. PAM isn't one of them. Privileged access is the control that decides whether a security event turns into an incident because lateral movement and escalation run on privilege. When a standing Domain Admin account is compromised, there's no second control waiting behind it.
The numbers say most organizations still carry that exposure. The Netwrix 2026 Data and Identity Security Report, based on a survey of 2,317 IT and security professionals, found that 66% of organizations keep standing, always-on access for some or most privileged roles, and 76% don't fully govern or monitor their non-human identities. The same research found that organizations where AI significantly expanded the number of identities needing access reported a breach in the past 12 months at nearly four times the rate of those where it hadn't: 43% versus 11%.
Insurers have noticed. In the Netwrix 2025 Hybrid Security Trends Report, 47% of organizations said they had adjusted their security posture to meet insurer requirements, and insurer demand for identity and privileged access controls rose between 2023 and 2025. If you're renewing a cyber insurance policy in the next 12 months, your PAM decision is also a premium decision.
Three things to do with the report before you talk to a vendor
1. Map the market definition to your own exposure
Read the Gartner definition of the market against a list of where standing privilege lives in your environment. In our view, for most organizations that means four places: membership of the Domain Admins group, local admin rights on endpoints (including the rights your AI agents now inherit from the user running them), service accounts with no owner, and third parties who still get in over VPN.
If you can't produce that list today, that's finding number one, and privileged account discovery belongs at the top of your requirements before any control does. You can't remove standing privilege you haven't found.
2. Turn the evaluation criteria into proof-of-concept use cases
Instead of sitting through a vendor's demo, hand them these use cases. Give every shortlisted vendor the same scenario and watch the parts they'd rather skip:
  • Request an administrative task, approve it, complete it, and confirm the privilege is gone. Then check what's left behind: accounts, Kerberos tickets, RDP still enabled on the target.
  • Kill a session halfway through and confirm revocation still happens.
  • Bind a session to a change ticket and see whether the ticket updates without anyone typing.
  • Time the path from install to the first protected system, with no professional services on the call.
Our PAM market guide has the longer checklist, including the questions to ask about administrative overhead once the pilot is over.
3. Separate architecture from feature count
Vendors in this market broadly fall into two camps. Vault-first products store and rotate credentials for accounts that keep existing between sessions. Zero-standing-privilege products create the account for the task and remove it afterward. A long feature list can hide which camp a product is in, so ask directly. The table below is the version of that conversation we'd want on our side of the desk.
You ask
Common answer
Answer you want
What exists between sessions?
A vaulted admin account with rotated credentials
Nothing. The account is deleted when the task ends.
What happens if the session dies mid-task?
Privilege remains until the next rotation
Revocation runs on session end, however it ended.
How do endpoints fit?
A separate product with its own policy
The same policy engine removes local admin rights and elevates tasks.
How long to the first protected system?
A services engagement
Hours, with agentless discovery running first.
None of this is a rip-and-replace argument. Bring Your Own Vault integration means you can keep the vault you've already paid for and put just-in-time control in front of it. The architecture question is about what happens to privilege when nobody's using it, not about whose logo is on the vault.
Where Netwrix stands
Netwrix is recognized in the 2026 Magic Quadrant for Privileged Access Management for the fifth consecutive year. In our opinion, that consistency traces back to building Netwrix Privilege Secure around Zero Standing Privilege from the start, in 2019, rather than adding just-in-time access to a vault later. We invite you to try it for yourself. Full deployment takes under a day, so the proof of concept above is a realistic ask.
Get the 2026 report
Read the Gartner 2026 evaluation of the market and the vendors in it in the complimentary 2026 Gartner Magic Quadrant for Privileged Access Management.
Gartner®, Magic Quadrant™ for Privileged Access Management, Paul Mezzera, Shubham Gera, Tarun Rohilla, Scott Brinker, 21 October 2026.
Gartner does not endorse any company, vendor, product, or service depicted in its publications, and does not advise technology users to select only those vendors with the highest ratings or other designation. Gartner publications consist of the opinions of Gartner's business and technology insights organization and should not be construed as statements of fact. Gartner disclaims all warranties, expressed or implied, with respect to this publication, including any warranties of merchantability or fitness for a particular purpose.
Gartner and Magic Quadrant are trademarks of Gartner, Inc., and/or its affiliates.
Share on
Learn More
About the author
Tyler reese headshot
Tyler Reese
VP of Product Management, CISSP
With more than two decades in the software security industry, Tyler Reese is intimately familiar with the rapidly evolving identity and security challenges that businesses face today. Currently, he serves as the Vice President of Product Management for the Netwrix Identity Product Portfolio, where his responsibilities include evaluating market trends, setting the direction for the Identity product line, and, ultimately, meeting end-user needs. His professional experience ranges from IAM consultation for Fortune 500 companies to working as an enterprise architect of a large direct-to-consumer company. He is CISSP certified.
