What is remote code execution (RCE)? How AI speeds up exploitation and how to limit the damage
Oct 19, 2026
Remote code execution (RCE) lets an attacker run commands on a system they don't own, usually through a flaw in a web application, CMS, VPN portal, or API. A successful exploit inherits the permissions of the vulnerable service, and many services run with far more access than they need. AI shortens the time from a disclosed flaw to a working exploit and lets attackers test thousands of exposed systems at once.
A remote code execution flaw turns a vulnerable server into someone else's computer. The attacker sends input the application should have rejected, and the application runs it as a command. AI speeds up the parts of this work that used to take attacker's real time.
Remote code execution is a vulnerability class that lets an attacker run their own code or commands on a target system over a network, with no prior access. You'll also see it called arbitrary code execution. Either way, the attacker decides what the machine does. An RCE vulnerability usually comes from an application that feeds untrusted input into something it executes: a shell command, a template, a deserialized object, a file upload handler. The RCE exploit is the specific input or sequence that triggers the flaw.
How remote code execution works
The attack usually runs in a straight line. The attacker finds an exposed system running a vulnerable component, sends crafted input, and gets code running under the service account. The first payload stays small, usually a web shell or a command that downloads something. Bigger tools come after the attacker confirms the foothold works.
Log4Shell (CVE-2021-44228) is a good example of how far one flaw can travel. Disclosed in December 2021 in the Apache Log4j logging library, it let a single crafted string in a logged field make a vulnerable server fetch and run attacker-controlled code. Log4j was embedded in so many applications that the bug turned up everywhere.
Most RCE bugs start small. The first function below hands user input straight to a shell. The second drops the shell and validates the input.
# Vulnerable: input goes straight to a shell
import os
def ping(host):
os.system("ping -c 1 " + host) # host = "8.8.8.8; id" runs a second command
# Safer: no shell, validated input
import ipaddress, subprocess
def ping(host):
ipaddress.ip_address(host) # raises ValueError unless host is an IP
subprocess.run(["ping", "-c", "1", host], check=True)
How AI changes remote code execution attacks
The vulnerability class is old. Attackers have changed how fast they can move through each stage.
Targets get ranked
Internet-wide scanning has been around for years. AI helps with the sorting: scan results can be grouped by software and version and ranked by how likely each system is to carry a known flaw, so attackers go after the best candidates first.
Patches become exploit tutorials
Vendors publish patches and advisories to help defenders, and attackers read them too. A model can take a patch diff or advisory and describe the vulnerable code path, which cuts the reverse engineering work and shortens the time between public disclosure and a working exploit.
One proof of concept, many versions
A public proof of concept usually targets one version or one framework. Models can port it to a different version or language and change the payload to dodge a known detection pattern.
Multi-step attacks need less skill
Many web attacks run in two stages. A small injection proves code is running, then a second step pulls down larger tooling. Models can draft that chain and retry it with changes when a stage fails, so running multi-step attacks against a CMS, API, or portal takes less skill than it used to.
The follow-up work runs on a script
After code runs, the follow-up is repetitive: read configuration files, collect keys and credentials, create a scheduled task, so access survives a reboot, and look for neighboring systems. Scripted and AI-assisted routines do these steps the same way each time.
The same chain, hundreds of organizations
A chain that works against one organization can be pointed at hundreds. Every stage above feeds the next one, and each extra target costs the attacker less than the last.
Stage | Traditional RCE attack | AI-assisted RCE attack |
Finding targets |
Manual review of scan results |
Results grouped by software and version and ranked by likelihood of a known flaw |
Understanding the flaw |
Slow, specialist reverse engineering of a patch |
Patch diff or advisory summarized into a description of the vulnerable code path |
Building the exploit |
Written from scratch or copied as-is from a public proof of concept |
Proof of concept adapted to a new version, framework, or language |
Multi-stage attacks |
Planned and tested by hand |
Chains drafted and retried automatically when a stage fails |
After access |
Operator reads files and runs commands one at a time |
Configs, keys, and credentials collected by scripted routines |
Scale |
A few targets per operator |
The same chain run against hundreds of organizations |
Defender window |
Time between disclosure and exploitation gives teams room to patch |
Less time to patch after disclosure |
What attackers do in the first minutes after an RCE exploit
The first moves after a successful exploit follow a pattern. Attackers drop a web shell or loader into a directory the service can write to, then add a scheduled task, service, or cron job so access survives a reboot. Next, they pull credentials and keys from configuration files and memory and start probing neighboring systems.
Each step leaves a trace you can check for. These commands show recent file changes in a web root and new cron entries on Linux.
# Files changed in the web root in the last 24 hours
find /var/www -type f -mtime -1 -ls
# Recently modified cron entries
ls -lt /etc/cron.d /var/spool/cron 2>/dev/null | head
On Windows, this query lists scheduled tasks registered in the last day. Turn on the Task Scheduler operational log first, because it's off by default.
Get-WinEvent -FilterHashtable @{
LogName = 'Microsoft-Windows-TaskScheduler/Operational'
Id = 106
StartTime = (Get-Date).AddDays(-1)
} | Select-Object TimeCreated, Message
Manual checks like these work on one server. Across hundreds of systems they fall behind, and an attacker who moves fast can finish before the next scheduled review.
How to prevent remote code execution and limit the damage
Patching and secure input handling are still the primary defenses against an RCE vulnerability. Everything after that assumes a flaw will eventually be exploited before the patch lands, so the goal shifts to catching changes quickly and limiting what a compromised service can do.
Netwrix Change Tracker watches the systems an RCE attack touches. It sets configuration baselines and uses file integrity monitoring to flag new or modified files, like a web shell added to a web directory, plus changes to critical system files and settings on Windows, Linux, Unix, and network devices. Its planned-change model compares what it observes against approved change requests, so a modification nobody scheduled gets flagged for review. The change history gives investigators a timeline, and system file authentication checks files against global reputation databases to confirm which ones are trusted.
Netwrix PolicyPak limits what an attacker can do once code is running on a Windows system. Least privilege enforcement removes local admin rights and sets elevation rules for standard users, so a compromised process has fewer permissions to work with. With PolicyPak, you can block applications and scripts from running if their file owner has not previously been whitelisted.
Remove local admin rights with PolicyPak
Try freeRemote code execution prevention checklist
- Patch internet-facing software on a defined schedule, starting with CMS platforms, VPN portals, and APIs.
- Validate and sanitize input, and keep user input away from shells, templates, and deserializers.
- Run services with least privilege and remove local admin rights where they aren't needed.
- Monitor web directories, critical files, and configurations for unplanned changes.
- Block untrusted applications and scripts from running on Windows systems.
- Keep a searchable change history so investigations start with a timeline.
FAQs
Share on
Learn More
About the author
Jarosław Bogalecki
Product Manager
Jarosław Bogalecki is a Product Manager at Netwrix, responsible for PolicyPak and Password Policy Enforcer. He has worked in technical roles since 2019, with a passion for product strategy, AI, and building solutions around real customer problems. Prior to Product Management, he worked in Application Engineering and Technical Consulting.
Learn more on this subject
Stopping real identity-based attacks with Netwrix Threat Prevention
How to safely decommission AD CS Web Enrollment
ESC9 vs. ESC16: same flaw, different blast radius
ESC8 is still the most common AD CS finding we see
Microsoft RAMP stops at the edge of your certificate authority
